VIP 222k setup help | SatelliteGuys.US
VIP 222k setup help
Caribecat
4
Puerto Rico
I have change my configuration I have two lnbs legacy and a subscribe vip222k. Fron the lnbs pointing at 110 and 119 I have wires running to each one of the sw21 (one wire from each lnb to each one of the sw21) From there I connected the two wires to each of the inputs of the vip 222k and when I run test switch its start to run saying 1 of 50 on each of the inputs. The I get message that both switches are disconnected.
Please help It would be greatly appreciated
It could be a loose or bad connection or wire. Switch could be bad. Also, it there a reason to start a new thread instead of continuing the one you started yesterday? Sometimes being able to read everything you posted on your current problem helps as some people may miss the previous posts.
Are these old school (DIRECTV compatible) dual lnbs (two outputs per LNB)?
The DISH 500PR features DP Dual LNBs that beg for DP21 switches.
Thanks; I found out cables from lnb to SW 21 are bad, Also Sorry for starting new thread but I couldn't figure out how to do it , now I know.
Thanks again for your help
Epix free for one month
Hopper USB Ports - all 3 dead?? 0 of 3 HDDs work??
