I upgraded to a Wally from my old VIP 211z. The Wally doesn't recognize the drive having content on it and wants to format the drive. Is there anyway to save the contents of the old drive so the Wally can use it?
The two receivers have different operating systems. The EHD is not interchangable as you are finding out.I upgraded to a Wally from my old VIP 211z. The Wally doesn't recognize the drive having content on it and wants to format the drive. Is there anyway to save the contents of the old drive so the Wally can use it?
That may be true but so did the H3 and my old 722.The two receivers have different operating systems. The EHD is not interchangable as you are finding out.
Ok if I have to format what is a good 1TB EHD replacement?The two receivers have different operating systems. The EHD is not interchangable as you are finding out.
I'd go for the biggest disk that will work. 2TB? (I don't know. My H3 has a 6TB on it.)Ok if I have to format what is a good 1TB EHD replacement?
I thought the Wally is limited to 1 TBI'd go for the biggest disk that will work. 2TB? (I don't know. My H3 has a 6TB on it.)
2TB maxI thought the Wally is limited to 1 TB
Not exactly, the incompatability is that the actual operating system for the recording apparatus for the 211 is stored on the EHD.So EHD's from VIP DVRs (612/722/922/etc) can be used on Hoppers because the file structure is the same, and the only data saved on the EHD is recorded events.
211/Wally's on the other hand use the EHD for more things, like the 9 day extended guide (2 day on internal memory) and the live TV buffer (the ability to pause/play/rewind up to an hour). This makes it so that Hopper to Wally/211 are not interoperable, and for some reason the 211 and Wally file structure is different.
I don't have a Wally available to me right now, but something I would try if you really want to transfer the recordings is what was mentioned above, after connecting a new EHD to the Wally and letting it format and create its specific file structure, connect both EHDs to a linux computer (the EHDs are formatted in ext3 iirc) and see if you can transfer the recordings over. You would just have to be careful to not transfer something that is not a recording.
What exactly makes you think that the OS is stored on the drive as opposed to the receiver?Not exactly, the incompatability is that the actual operating system for the recording apparatus for the 211 is stored on the EHD.
The Wally's os is graphical whereas the 211/411's os is not therefore the Wally will reformat the drive and install it's graphical operating system to the EHD and in the process wipe out all other data on that drive.
The operating system, itself, is located on the receiver. The DVR system on on the 211 and Wally is located on the external hard drive. So, the way that drive is set up may be different than the Hopper which has all of it on it's internal hard drive.What exactly makes you think that the OS is stored on the drive as opposed to the receiver?
Unless either of you have found software on the EHD, I don't know how you can determine that. The non DVR part of the software has to reside in the receiver or it could not function without an EHD. Now there's extra stuff like the longer guide, trick play buffers and programs and (in the case of the Wally) channel or program icons. But the O/S? I don't see why.The operating system, itself, is located on the receiver. The DVR system on on the 211 and Wally is located on the external hard drive. So, the way that drive is set up may be different than the Hopper which has all of it on it's internal hard drive.
TO TheKrellUnless either of you have found software on the EHD, I don't know how you can determine that. The non DVR part of the software has to reside in the receiver or it could not function without an EHD. Now there's extra stuff like the longer guide, trick play buffers and programs and (in the case of the Wally) channel or program icons. But the O/S? I don't see why.
Also note that the H3 can function without an internal drive, so the O/S isn't on that drive either.
The hopper does use the hdd to store all that extra info as well. When there's a hdd failure on a hopper all that stops working. And to the other post about the OS, it's part of the receivers firmware which is permanently stored on the receiver itself and not the hdd. Adding a hdd to wally basically makes it the same as a hopper.So EHD's from VIP DVRs (612/722/922/etc) can be used on Hoppers because the file structure is the same, and the only data saved on the EHD is recorded events.
Limited time offer
