ViP 211K receiver | SatelliteGuys.US
ViP 211K receiver
cams
8
Arizona
I need to know if I can use a Dish 500 pro quad LNBF antenna with a ViP 211 receiver? if not, which dish/antenna do I need? Thank you.
You can use it, but the dish 500 will only pick up 119&110. If you need, or want HD programming with it, you will need a 1000.2 (119/110/129), or 1000.4 (61.5/72.7/77)
1000.2 is the full western arc dish to get HD
1000.4 is the full eastern arc dish
In Arizona, you'll want the 1000.2 so you get satellites 119, 110, and 129. The 129 satellite carries most of the HD channels on western arc
You could add a second dish and point it to 129. Then join the 2 with a switch. What Lnb's do you have on the 500? Dish pro or Legacy?
The OP has a DP Quad on the 500, which does not have a satellite input
You're right though, the OP can add a second dish for 129, and get an external switch to combine the 500 with it
auto shut off feature
Is it customary to tip the installer?
