With no 2 year commitment correct? Since I bought all my own equipment.Activation fee of $99.
no fees....you just pay for the 1st month up front
no commitment
I had a account like that a year ago. 211k with a WA dish....all I paid was the month up front
Best to contact a DIRT member here to get set up. Their names are in red
http://www.satelliteguys.us/forum.php
I don't have one right now. I was going to get a new one. Do they come with the access card?Is it a new receiver or pre-owned?
When you go into the system info screen what does the smart card # start with? S00 means new card...S19 usually means you're OK (some of the older ones do require a new card)
yes the new receivers have a access card. Some are built onto the motherboard so when you open the card slot you wont see one. But any new receiver will have the smart/access card in it
Charleston. I tried to get a EA a while back but for some reason they said I needed to get my locals from 129 which is on the other side of the hillside. EA satellites are clear (not a tree in sight)your loc says WV....do you know what locals you will get?
reason I ask is some markets are on WA
Clarksburg, Parkersburg and Wheeling are on WA
Charleston and Bluefield are on EA
wrong. There is no fees for a self installed setup
sounds like a winner. And if you decide to cancel you can sell the receiver
Limited time offer
