I have an ultra that I want to use on FTA. How do I know it is factory state and how do I get it there?
Boot loader .12
Main S/W 1.43
Satelite U007
Thanks for you help. Now all I need to do is cut a hole in my neighbors house to see the satellite.
Koodos to this site. There are so many "FTA" sites on the internet you don't know what you are getting into.
I thought the 1.43 was legit software. I am using 1.46 for my TRUE FTA and I see no traces of the "haxxorz" options in there. I am running U00D for my sat list too.
Yes Sir you are correct,the 1.46 is the latest factory file that i know of for the Veiwsat Ultra!
If 1.46 is dated 100902U New Factory Firmware you should read the release note as I mentioned it in my original post:
(by the way corruna if you want this one let me know and I'll e-mail to you)
"Please make sure you get the correct file for your receiver.
If you update these files(100902), you can't downgrade to old files. If new files do work, the old ones should not work either."
VS Team make them not to downgrade to prevent clones.
Enjoy!!
75% signal, flashing quality no higer than 355. Can I assume this is a signal issue?
Limited time offer
