Viewsat set up | SatelliteGuys.US
Viewsat set up
larven08
i just bought a viewsat extreme a month ago and last week the S bar and the Q bar were at 0%:(what should i do to make it go up!!!!
Welcome to satguys.
You should really start a new thread, not hijack someone elses.
As for being at 0, well I assum you mean it was working and if that is the case, then since signal and quality are at 0, then I would say you have a bad connection.
I believe the viewsat will show signal still if the LNB is still connected, but no quality if sat is not on an active TP
broke off from other thread
Well.....a little more info would help
-Dish size
-LNB Type
-Motor involved?
-satellite aimed at if not motorized?
Anything different happen recently?
New Viewsat Extreme Need Help :)
Galaxy 25, TP 24 12122H
