Viewsat pro adding satellite | SatelliteGuys.US
ronithayer
16
United States
I purchased a used viewsat pro and I have deleted all channels from it. I would like to add AMC 21 at 125W. It is not in the satellite list so I was wondering how I can add that satellite? Also can a new satellite list be loaded using a usb flash drive? Any help would be great you guys have been so helpful so far. Thank you
Under installation click on select satellite at the bottom of the screen I believe it says new. I think its the blue button on the remote. Use the remote key pad to enter in your new sat. Once done highlight it and save and exit. Go into antenna settings select your new sat. and now your can enter in settings.
