ViewSat Extreme 2000 Installation problem | SatelliteGuys.US
Welcome to the SatelliteGuys.US FTA forum!
Let us know the exact make and type of LNBF you have, if its a Standard the L.O. should be 10750
If its a Universal the L.O. should be 9750-10600
Hopefully the Pay channels are scrambled :)
Looks good! If you are getting all those pay/scrambled channels you are NOT on G10R
What are you using to motor the dish DiSEqC 1.2 or USALS ( or hand ?)
You may have to enter a LIVE TP from G10R then use DiSEqC 1.2, motor over until you see signal quality.
please dont use the bold feature...its not needed
calm down. Its probably just something not set up right :)
Let me explain something Holmes. I'm staff here so I can really do what I feel. I asked not to use bold. It is not needed and isn't going to get your questions (or should I say ramblings) answered any quicker.
I read your original posts and they didn't tell me much. So let me ask a couple questions
If you are trying to pick up G10, the best thing might be to use the fixed dish and not the motor. But if you are looking to motorize, what is your zip code/general area so that we can give you the right angles to aim the dish and your true south satellite
DishSkinz
Mexican Channels
