viewsat equipment info | SatelliteGuys.US
smithjch
Thanks for the forum,
I hooked up the viewsat 2000 to my directv dish got signal strength from the echostar satellite but it failed to pull in the signal.
I talked this over with a friend and he said I needed a different lnb
Is the lnb type a dual lnbf fss ku standard or universal the best for an 18" dish aimed 110 and 119? Is there a certain frequency range I should get?
Also, I have another 18" dish that I could aim farther west. Again what is the best set up for this?
Thanks for your help.
Help with equipment for ku band reception
Signal Level vs Signal Quality
