Verical mount for 510? | SatelliteGuys.US
feeth
4
Vertical mount for 510?
I did a search and saw this thread about the 508 being mounted vertically:
Its post # 6487. I can't post a link till I have at least 5 posts. Even one from this site. :no
Has anyone every mounted a 510 vertically?
I want to mount it behind the TV.
The UHF antenna will still get me a remote signal.
Thanks!!!
I don't know. But if you can vertically mount a 508 without problems, you can with a 510 because they are practically the same receiver.
The problem with hiding away receivers is that they are usually placed in confined spaces. The receivers cannot ventilate as well, and they can overheat.
Thanks!
Put the receiver on its side with the top/rear facing an open area. It should be able to cool well.
Works great!
Rca Wireless Phone Jack Blues
95 cm dish 3 lnbs ??
