various FTA sats and what's needed to get them | SatelliteGuys.US
syndicate1
23
Ottawa
There have been alot of questions lately about what's on other satellites besides Dish and ****. Here are some things to remember about watching true FTA.
Your 18" or 20" dish with Direct TV/Dish/ LNB will not work! For one thing, the dish is too small to pick up the lower frequency signals from the FTA sats. Secondly, the Dish/ LNB is for 12.2-12.7 GHz circular (right-left) polarity. Ku FTA sats require 11.7-12.2 GHz linear (horizontal-vertical) polarity. C-Band sats require a C-Band LNB . Using your Dish Net LNB for FTA is like trying to tune into AM stations on an FM radio.
Some satellites, such as Galaxy 10R and Telstar 5, have both C-Band and Ku-band capability. This does not mean that you can use a Ku dish to get C-Band signals or vice-versa. Listed below are the dish requirements for each satellite and/or band allocation.
Here's the lowdown on various FTA sats and what's needed to get them:
30" Dish, Ku Linear LNB (4-foot dish in Alaska/Hawaii/Canada/Carribbean) :LOF1/2 = 10750
Galaxy 13 (127W) : Chinese Channels
Galaxy 10R (123W) : UPN , WB, Fox, CBS, ABC Affiliates from Little Rock, Cheyenne, Burlington, Virgin Islands, and others; Pentagon Channel; STEP Star Education Network; KBS America; Univision and Telemundo affiliates; The Tube; Mas Musica; Veterans Affairs; radio stations
AMC-1 (103W) : NBC feeds (these are sporadic and you'll need a blind search receiver to find them)
AMC-4 (101W) : Religious channels; Foreign Channels; Lawyers TV; RTP
Telstar 5 (97W) : Daystar TV; Globecast; hundreds of Foreign TV and radio channels.
Telstar 6 (93W) : CBS and ABC feeds (need blind search receiver); Lord & Taylor
AMC-3 (87W) : PBS stations (requires AC3 audio capability)This sat is not available in Alaska/Hawaii
AMC-5 (79W) : Utah Educational Network; Empire Sports Network This sat is not available in Alaska/Hawaii
SBS-6 (74W): Ohio News Network This sat is not available in Alaska/Hawaii
AMC-6 (72W) : Comcast Southeast This sat is not available in Alaska/Hawaii
C-Band 7 to 12-foot dish and LNB :
LOF1/2 = 5150
AMC-8 (139W) : PBS affiliate from Fairbanks; ARCS (programming from Anchorage network affiliates for rural Alaska residents); University of Alaska telecourses; Gavel to Gavel Alaska This sat is not available in Canadian Maritimes
AMC-7 (137W) : Anchorage local stations This sat is not available in Canadian Maritimes
AMC-10 (135W) : Tech TV (requires AC3 audio capability) This sat is not available in Canadian Maritimes
Galaxy 1R (133W) : California Channel This sat is not available in Canadian Maritimes
Satcom C3 (131W) : Bloomberg TV (requires AC3 audio) This sat is not available in Canadian Maritimes
Galaxy 13 (127W) : RFD-TV This sat is not available in Newfoundland
Galaxy 10R (123W) : Outdoor Channel
Telstar 13 (121W) : Fuse; STC (requires AC3 audio capability); TV Washington; Sportsman Channel; Q TV Network (gay and lesbian channel, requires AC3 audio capability)
Anik F1 (107W) : CTV network (requires 8PSK capable receiver); ASN; Newsworld International; French channels
AMC-1 (103W) : Pax feeds; XYTV (requires AC3 audio capability), religious channels
AMC-4 (101W) : NBC network feeds; religious channels, UCTV
Galaxy 4 (99W) : Religious channels
Telstar 5 (97W) : TCT World, Urban America TV; BYU TV
Galaxy 3C (95W) : Voice of America TV; Horse racing channels; Equity network feeds
Telstar 6 (93W) : CBS Network Feeds (blind search required); CBS HD network feeds (must use HD-capable DVB-S card)
Galaxy 11 (91W) : WB network feeds; Independent stations from L.A.; Fox Movie Channel; EWTN
AMC-3 (87W) : Associated Press; Michigan Gov't; TVU This sat is not available in Alaska/Hawaii
For more detailed info on frequencies, symbol rates, and PIDs, visit www.lyngsat. com
True FTA Sats and Required lnb's
Here is a list of satellites and the correct lnb's to use with them:
61.5W Echo 3 - use standard circular lnb - 11250 MHz
63W Estrela - use linear lnb, either universal or standard linear- 10750 MHz
71.8W Nahuel 1- linear lnb, either universal or standard linear- 10750 MHz
77W Echo 4 - circular standard lnb - 11250 MHz
79W Amc 5 - linear lnb, either universal or standard - 10750 MHz
82W Nimiq 2 - circular standard lnb= 11250 MHz
87W Amc 3 - --- linear lnb, either universal or standard - 10750 MHz
91W Galaxy 11- linear lnb, either universal or standard- 10750 MHz
91W Nimiq1&3- circular lnb standard= 11250 MHz
93W Intelsat 6- linear lnb, either universal or standard-10750 MHz
95W Galaxy 3c- linear lnb, either universal or standard - 10750 MHz
97W Intelsat5- linear lnb, either universal or standard - 10750 MHz
101W Amc 4 - linear lnb, either universal or standard- 10750 MHz
103W Amc 1- linear lnb, either universal or standard- 10750 MHz
105W Amc 15- linear lnb, either universal or standard- 10750 MHz
107.3W Anik - linear lnb, either universal or standard- 10750 MHz
110W Echo 8 & 10,X - circular lnb standard - 11250 MHz
111W Anik f2 - linear lnb, either universal or standard - 10750 MHz
116.8W Satmex5 - linear lnb, either universal or standard - 10750 MHz
119W Echo 7 - circular lnb standard - 11250 MHz
121W Echo 9 - linear lnb, either universal or standard - 10750 MHz
123W Galaxy 10r - linear lnb, either universal or standard - 10750 MHz
127W Galaxy 13 - linear lnb, either universal or standard - 10750 MHz
129W Echo 5 - circular lnb standard - 11250 MHz
148W Echo1 & 2 - circular lnb standard - 11250 MHz
I did a google search for "This does not mean that you can use a Ku dish to get C-Band signals or vice-versa"
This is, word-for-word, a copy and paste of a post circulating around numerous hack sites. The earliest of which, according to google, appeared in 2005. Based on some of the satellite names, It might even be even older.
Not helpful in the least.
closing this thread due to ancient info...good lord where the heck did that come from?
Equity on 123 has been gone for over a year now
Empire Sports Network??? SERIOUSLY??
That station has been defunct since 2005
Let's Talk Feedhorns
splitter usage
