V-Box 7 Diseqc Pos/cont | SatelliteGuys.US
hossebuck
On Vacation
27
Hampton, Ga. 30228
This box has the wrong manual for the remote. Does not privide the way to delete a poistion put in by error.
This should teach one how to get all facts before dealing with certain suppliers. Need the correct manual or instruction
as how to delete just one satellite position. thanks,
hossebuck
I might be corrected by another member, but I don't believe that a single DiSEqC motor position can be deleted from controllers like the Vbox/Gbox or even in DiSEqC motors. Unless a device reset is perfomed on the controller or a DiSEqC motor, the positions stays as set.
I know that a DiSEqC 1.2 position number can be overwritten in a controller/motor and a position number can typically be reassigned in the receiver.
You are correct there is no way to delete just one. You have to reset and delete them all.
It's starting to look like mid December around here.
How do you know what you know?
