Using Sling | SatelliteGuys.US
Using Sling
Add me to the list of users that would like this option as well. Our TV2 is practically in use all day and I can't use it while I'm at lunch at work.
I know it's technically possible. If you get your password and login with the Sling app you can see three inputs that you should be able to switch to. I get kicked out when I try to swap, but it is obviously in there.
Thanks for listening!
DishOnline Extraneous Receiver Listed
Comcast - what the..
