Using Loop Out | SatelliteGuys.US
Using Loop Out
Keystone7
507
74
North Indiana
Hello,
I was wondering if I am doing something wrong? I am using two dishes on a DiSEqs switch. I can see and use both satellites fine on the main box (CNX-Nano). I am using a SV-360 Pro for the second box on the (Loop Out) from the CNX-Nano. I only recieve one satellite on the second box. I have tried every settings possible on the second box. What ever satellite I have the CNX-nano tuned to with the rotor is the only satellite I can what on the SV-360 Pro. The question is, why can't I watch both satellites on the second box? Need some help here, or maybe that's what I am to only get on the second box. Thanks for any help!
keystone7
you need a 3x4 (or 2x4 if it exists) switch to have both receivers independently selecting any dish/polarity. but you will also need a coaxial cable going from the switch to the second receiver instead of the master/slave loop out connection.
PBS HD East (no sound)
87w ku
