Have you tried using seperate imputs to your TV instead of daisy-chaining them? I, too, tried what you are doing when I first got the 811 but went back to seperate for 2 reasons. 1. PQ. 2. PIPI have my 508 connected in the back of my 811 with the RCA jacks into one of the video inputs
MikeF said:Have you tried using seperate imputs to your TV instead of daisy-chaining them? I, too, tried what you are doing when I first got the 811 but went back to seperate for 2 reasons. 1. PQ. 2. PIP
Kevinw said:If your 811 looks great in SD it is beacuse you have your brightness/contrast cranked real high. Lowering the contrast and brightness will keep your 508 from looking faded.
peid said:I need some questions answered here too.
I currently have the 811 hooked up to my HD RPTV.
I got this wild hair the other day wanting Tivo so went looking last night and the guy told me just to get the 508 from Dish. No monthly fee etc.
So, what is the proper way to hook up the 508 and the 811 to the same TV.
If I hooked both up direct to the TV, would I have PIP? I also only have one cable direct from the satellite to the back of the 811. Do I need two cables or can I split the signal? Or do I run in the back of the 508 the out of the 508 into the 811?
I can get a brand new in the box left over stock 508 for $275. Is that a good deal?
This board has been very helpful on numerous situations and I hope you can help on this.
Please give pros and cons to either way I hook up or not to hook up. PQ etc?
I do understand the 811 will be the HD source, but I shouldn't notice a difference between the 508 and 811 on SD should I?
Limited time offer
