Used DirectTV receivers | SatelliteGuys.US
stecle
380
220
Between the North and South Pole
I didn't know where to put this so it ended up here. I was doing some spring cleaning yesterday and found 3 old DirectTV receivers. They are a DRD 502,DRD 222, and a DRD 420. I also have a DirectTV access card in its original unopened package. Are these worth anything or should I throw them away?
The recvrs are MPEG2, so you would not get much if you did set them up (some SD I suppose), the access cards are more than likely an older generation so they would not activate them anyways ...
But the MAIN problem besides all that is...none of those receivers have RID's, so right there you are SOL w/DirecTV ever activating them as new... ;)
I will buy the cards I use them on my key chains. I have to post some pictures everyone loses seeing the the cards which I usually have on my zipper pulls on my laptop bag. Dish and Directv. Yes I know that they technically belong to DTV and Dish but they have never asked for them back.
cinema wireless connection kit
no signal
