Just want to use ONE EHD and Fan at a time. So again, will that work or will the fan confuse the 722?I have my laptop cooler plugged into the back, with a passthru connector, and my EHD plugged in to that.
Of course, if you're using a hub, you'll only want one of the HDDs powered up at a time.
The receivers do not support USB hubs YET.... however I hear they are working on it and will be able to hook up more then one EHD to your receiver.![]()
Thats a no at the moment.So it that a NO for a hub with fan and one EHD?????????
Will both work, with a hub in the rear of 722K, or does one need to be in front?
Are these fans, usb or otherwise thermostatically controlled or do they just run all the time?
Limited time offer
