USB Flash Drives | SatelliteGuys.US
USB Flash Drives
vegassatellite
3,319
174
Phoenix, AZ
Will a USB flash drive work with a DISH receiver? Looking for a solid-state option to hard drives and interested in storing individual shows, small blocks of content, etc. I like the idea of a movie collection being on solid-state media instead of DVD, etc.
FLASH drive will not work.
It must be a hard drive.
From Dish Network web site:
While most major manufacturer external
hard drives are compatible with the ViP622
& ViP722, a minimum 40GB and maximum
750GB drive is recommended.
Additionally, the files on the EHD are encrypted and can only be viewed on the DVR.
In fact people we have had mixed reports in other threads about whether people can use the falsh drives even to move pictures etc. FWIW I have done that and it worked fine but my experience apparently is not universal.
I have had very mixed results using flash drives for this type of application (not with dish receivers, but other setups). Being solid state is nice, but they do have a failure rate that increases significantly the more they get used and this type of setup seems to hammer the storage medium heavily.
A good idea of what happens is when I did an experiment with 4 USB flash drives setup as a RAID 5 config. Just for kicks, I copied gigs of data to the drive, removed a USB stick and reinserted to rebuild the array. Seemed ok for a while, but within a week or so, 2 of the sticks failed completely and reported no storage space.
I have only tried it one way. Maybe youa re on to something maybe I misunderstood what others tried to do.
Well, if viewing photos is the only thing that can realistically be done, then I have some ideas to incorporate with that.
Does DISH charge any upfront or recurring charges to be able to view photos from a USB flash drive?
No. I plugged in a flash drive with photos and it worked fine and I do NOT have EHD activated. My panasonic plasma has an SD card slot though, and I had more options viewing photos that way. The USB flash drive into a 622 does work, however, even if EHD is not activated. At least mine does.
Which receivers can view photos on a flash drive?
I'm not sure if any will read off the flash drive, but I'm sure someone else can give the yes or no answer. I think I'm right to say that my old 921 would read a digital camera through the USB port so you could view photos that way, and, going out on a limb here, I think all the newer dvr's would do that. Just don't quote me on that :)
Rob
Anyone know if you can move photos from a flash drive onto the 722 so that you can view the pics without having to have the flash drive inserted?
It's been a while since I played with this, but I think that although I could read the photos directly from the flash drive, in order to MOVE them to the 622 I think I got a pop-up telling me that the feature was not available.
Like I said, it's been a while. But plug in a flash drive and try it. Also have a look at your TV. Not sure what you have there, but my TV had far more options for displaying the photos than the 622 did.
HD Only Package
No Stereo Sound on FOX
