USB 3 port problems with USB drives | SatelliteGuys.US
dweber
1,834
2,650
Plain City, OH
I have read several posts from people having problems with USB drives disconnecting from the USB 3 port. They claimed the drive worked fine on the USB 2 ports but quit after several minutes when using the USB 3 port. How many are having this problem? For those having the problem, what model Drive are you using? This is important for me because I have 3 drives connected to my 2 hopper with sling receivers.
I have my EHD and OTA module plugged in but I don't know which ports they are hooked up to. I wasn't able to see when I plugged them in. Both of mine work great.
I was having the problam and i am using a wd hard drive. Seems like better now. The biggest problem was transfering files from ext drive to h3. It was disconnecting randomly. Or not seeing the drive when i plug to usb 3.0. No more problems though other then if you want to transfer a recording from hopper to ext drive you have to wait to drive to come online or hopper freezes.
Can the Joey2 or 4K joey do PIP?
Any success in programming the 52 remote via IR?
