UPS? | SatelliteGuys.US
UPS?
beware
23
St. Louis
I have had quite a few irratic pauses or pixelating issues with directv over the last few months and they recently went away but then I got a decent issue just recently.
I was told on directv's forum that it is probably a electrical interference and they have suggested a ups.
http://www.amazon.com/Tripp-Lite-BC3...FI6/ref=sr_1_9
Looking into that but how do I determine what the voltage of everything I want to plug into it? I don't want to buy something and I need more voltage but I also don't want to speed a lot of money.
More likely you simply have a signal issue. Does this happen on more than one receiver? Have you checked your levels?
How often does this happen? Couple times a week? Couple times a day? Every few minutes? If it's happening on all and it's at most a couple times a day it's no biggie.. Could be something like airplanes flying through your LOS.. When you're near a large airport like STL they'll be a lot lower and slower (I used to live in the approach path to Newark :D).
Having a UPS is a good idea, but I don't think that's your issue. Can you post your signal strength numbers for all of the satellites?
What dish/lnb to get for travel?
Adult VOD expires?
