- Sep 9, 2003
- 12,379
- 2,109
I am looking for a Uninterrupted Power Supply that either has no audible alarm or one that can be disabled permanently without a computer. can anyone help or am i just dreaming?
Alarm Delay Enable • Enable
• Mute
• Disable Mute ongoing alarms or disable all alarms permanently
Thanks Ilya but both of those companies have told me that they do not offer an UPS wihout an alarm and do not intend to.
The "ON/OFF/TEST" button will silence the current alarm. While the ON/OFF switch on the back will prevent future alarms. That's what the manual states: When in the OFF position, the audible alarm will not sound when the Belkin PureAV Battery Backup is in the backup mode.
Also here is what some online user reviews state: One little feature I *really* appreciate is the switch to disable the "on battery" alarm.
Or this one: ...offers a UPS function with the ability to turn off the alarm.
If you are still not convinced, then call Belkin and ask them what does that switch on the back do.![]()
Limited time offer
