GEOSATpro - Upgrade | SatelliteGuys.US
GEOSATpro Upgrade
freewave
22
northen Ontario
I would like to upgrade my microhd via usb however I do not want to loose my satellite positions. Would I just do an upgrade without a reset or is there some kind of prossess that I can do to accomplish this task.
Regards
Save your user database file to your USB stick before upgrading then reload, when done.
If updating from a firmware version older than 0.13, we strongly suggest that you do not load the old User Data Base file as it may be corrupted. You should follow the update instructions and perform a Master Reset after updating the firmware then rescan the channels. This extra step may save you a lot of frustration in the future if a corrupted .udf file causes the receiver to start power cycling.
Please review this post if you have any questions about the suggested procedure. http://www.satelliteguys.us/threads...USB-and-Satellite-Update-(OTA-SSU)-12-05-2012
GEOSATpro Channel renaming
GEOSATpro Request: Updated microHD Graphics
