Upgrade (522 -> 722) Keeping 622 | SatelliteGuys.US
  • Thread starter Thread starter bradb007
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
bradb007
SatelliteGuys Guru
145
I already have a 622, but am needing to replace my 522 (harddrive has already been reinitialized twice to extend its life, thanks to tips here thanks SatelliteGuys!).
The current setup is 2 dish 500s on the lease program.
I have the 622 fed into my main TV downstairs (dual tuners for a single TV).
I have a 522 that is fed 2 inputs in the office and backfeeds an output for TV2 to the master bedroom.
Ideally I would like to shift the 622 upstairs and place the 722 downstairs. Does anyone know if there could be the potential for any new wiring/switches during this process or will the existing cabling likely be sufficient to support these systems?
IE should I just do the swapping myself or is there a risk that I need a prof installer to come do some switch stuff.
Installing OTA antenna using DISH coax?
DISH Network Van hit by fleeing suspect in High Speed Chase
