Upgrade 211 and use 311 Second Reciever | SatelliteGuys.US
lilsaxon
12
Can you upgrade to a 211 HD and still use a 311 as second reciever in your programing package, or do you have to change both recievers to 311's. Thanks.
YES, you can upgrade to two 211 so you will be able to watch the HD programming on both TV'S. I believe you gonna pay extra for the second 211 receiver upgrade. If you don't have a HD tv on the second TV I will keep the 311 for the second TV.
Best, Jose.
Thats what i was wondering. I have a 301 and 311 and did not know if you could add a 211 HD and that all recievers would be compatible together in your programing package. Thanks.
Yep, both receivers will work fine together. Just remember that even though you get the 211 and pay extra for one of the new metal packages only the 211 will receive the new MPEG 4 channels (not your old box that you are keeping active).
DISH Episode Numbers on 622/942 wrong?
my upgrade story this morning...so far, not good
