Updates to the tech portal | SatelliteGuys.US
jkinser
127
Minneapolis, MN
Updates to the tech portal (411 Receiver)
Dish has updated the tech portal to include information on the 211/411. I would post a link, but I don't have enough posts yet. All new information is contained in the HDTV section. It also includes some better resolution picture of the box's front and rear panels.
Here is the important information on the 411:
Technical Aspects
4.1 IR Universal Remote (1)
Advanced MPEG-2 and MPEG-4 compliant Explain
Method to compress digital signals. This way, the amount of information that has to be sent decreases. MPEG is a compression method. Thanks to this compression, it is possible to combine several channels onto one satellite transponder.
DISH Comm Explain
DISH Comm allows supported receivers to communicate with each other through the electrical plug and house AC wiring and be able to see if one of them has a phone line connection. When it is time to download PPV purchases, the receiver will route the information to the phone line connected receiver to dial out and report. This communication will include information of which receiver the purchases originated. One DISH Comm receiver must be connected to a phone line.
Front Panel Buttons (5) Explain
Power, System Info, Up, Down, Select
Front Panel Lights (1) Explain
Power (green)
IR Blaster Explain
Sends an infrared command to VCR to record programmed shows.
Low Battery Indicator Explain
If the remote control batteries are low, a small "Low Battery" text indicator appears in the view banner whenever the view banner is displayed.
Power supply draw: 0.15 - 1.25 amps, average 0.25 amps; 15 - 230 watts, average 60 watts, exact on back panel
Smart Card door (a Smart Card is not used; Smart Card technology is built into the receiver)
Software upgrades via satellite
Software Version Control Explain
Software Version Control will allow some receivers to self-maintain their software version.
Standby Reset Explain
Standby Reset helps to reduce problems by clearing errors encountered over the previous 24 hours.
Super Diagnostics Explain
Super Diagnostics allows faster access to important system information and settings. Press Menu - Menu to access System Info 1. Hot Key explanations are available under How To.
SuperDISH support
System Information available at a button push Explain
Press the Sys Info button on the receiver.
Wireless Phone Jack support
Connectivity
Back Panel
3-prong power cord
(1) Satellite antenna input, blue F-connector
(1) Telephone Jack; not compatible with VoIP (broadband phone)
(1) TV antenna/cable input, black F-connector
(1) HDTV Digital Audio/Video output (HDTV TV1)
(1) Set Y/Pb/Pr High-definition Component output (HDTV)
(1) Dolby Digital/PCM digital optical output
(1) S-Video Output (SDTV)
(1) Set RCA-type audio/video output (SDTV)
(1) Modulated TV Set output
(1) USB 2.0 port for future use
(1) Ethernet port for future use (211 ONLY)
Dish Network Adds Fox Reality Channel
different dishes -- what are the differences?
