UHF Remote to Control TV1 722K | SatelliteGuys.US
handymantoo
SatelliteGuys Guru
138
northeast
My 722k receiver is not next to the TV. I have an extra UHF remote. Can I program it to control sat TV1 via UHF so that I do not have to point in two directions to control TV and Sat?
I always thought the 722 did not support the UHF on TV1. You would have to get a UHF kit if I am not mistaken.
Take the battery cover off of the remote, and make sure the "1" key is facing out (if it's the "2", the key can be pulled out, and flipped around).
Also make sure the switch next to the batteries is set to the "UHF" side.
Once you have done this, take the remote to the receiver
Press system info on the front of the receiver
Press record on the remote 3 times.
The remote should now be programmed to the dish receiver as UHF for TV1.
Hopper 1080p24 or 1080i?
20.0 Remote Control Volume Stereo Receiver
