uhf antenna | SatelliteGuys.US
uhf antenna
chuckwl3
2
dellwood
can anyone tell me how you move the uhf antenna to the actual tv fir tv2 am having interference and need to move it so uhf signals will work tv2 thanks
Very easy. Just connect some coax to the UHF antenna out. Get a female/female coax adapter and then attach the antenna to that. Experiment where you can place it and eliminate the interference. That's what I did.
You take a common 2 way splitter. Use 2 short pieces of coax and connect the TV2 ouput and the RF anntenna ports to that. Then connect the line going to the TV2 to the other port of the splitter. Where your TV2 is located put another 2 way splitter with the Antenna connected to it, the line from the receiver, and a short piece to your tv.
Try the B-band (UHF) for TV2. It is more powerful. This often is the fix before having to go to the trouble to insert it in the coax.
Service Plan - minimum subscribe period?
Dish network VIP722K in a cruise tv antenna in my rv from a newbie
