Udating Sat lists on a CoolSat 5000 | SatelliteGuys.US
leifkenn
60
Colorado
Hello,
I was curious if anyone could point me in the right direction.
I have a CoolSat 5000 whose Sat lists are way out of date and I would like to update them.
Is this possible easily and if so what software do I need.
I run Linux on my PC.
I have attached the loader and my "master" list of sats.
Has 30-148 on KU
72-139 on C-Band
and a list of transponders that are up 24/7
unzip both files
open loader
at the top find the tab that says "channels"
click "browse"
find file called "master"
hit "connect"...it will show the software version in the receiver
press "start" and let it download to the computer
you do need a RS232 cable to do this...that is the only drawback
Thanks For the files
Has 30-148 on KU
72-139 on C-Band
unzip both files
open loader
click "browse"
I really appreciate it and will work on it this weekend.
Here is the options Channelmaster can export too. PLease note this wont work with all models
ariza
blackbird
buzz
captiveworks
conaxsat (also Geosat)
Coolsat
DGStation
Digiwave
Dreambox
ExtremeView
Fortec
Lava
Megasat
MVIDEA
My Theatre
Neosat
Neusat
Orasat
Pansat
Skyview
Sonicview
Spacestar
Supersat
Triple Dragon
Viewsat
Dont mean to hijack, but I'm thinking of getting a CS 5000 or CS 6000. Iceberg or anyone, would you say the 5000 and 6000 are on equal ground as far as blind scan? Thanks.
the 4/5/6000 models are really the same. The 4000 is usually in a black case, the 5000 had black or silver and the 6000 I think was just black
the 6000 had more "EPG memory" which is useless for us ;)
You cant go wrong with any of those 3
Changing APID on CS5000?
Motorized dish setup
