U503 comments. | SatelliteGuys.US
U503 comments.
Just downloaded 503. Still doesn't recognize that I have an OTA donge. It'll be a couple of days before I know if it reliably records scheduled programs. Currently
I have to check daily or it randomly skips scheduled episodes.
Reactions: pattykay
U503, If I understand it correctly, was meant to repair problems with first time set up like the receiver not running a check switch, activation problems, etc.
I noticed yesterday that I was no longer getting the screen issues on my OTA channels. I checked the version and I was at 503 as of 10/11. it appears to have fixed my OTA issues.
Reactions: HipKat
Got my Joey connected to Dot. Another user said to unlink then relink Alexa account on Hopper, once I did both Echo & Dot were listed with the 2 receivers & both are now (somewhat) controllable - wish it had more commands though.
Everything seems to be working at the moment. I still have 502. I think I will just wait for the 503 download to hit me..........hope it's a soft landing.
I hope you guys with the Echo Dot are using it for the 1000's of other things it can do besides change the channel on your receiver. I have mine paired to about 50 different skills and looking for more. I love this little hockey puck
Reactions: BamaFan2
I am happy for you. Mine is still broken.
I have had no ota problems till we got the U503 software. Since then I have missed two different recordings on tv shows and the news and my wife said this morning she couldn't even tune to ANY of the ota channels at all. Which is why I missed my GMA recording on my ota ABC station this morning. I unplugged my receiver and rebooted it and it seems to be working again. For now.
Reactions: charlesrshell
I am having OTA issues too. This morning while checking my schedule for the week noticed OTA timers not scheduled. So deleted the timers and tried to create new ones. In the guide when I select the program to record I am not seeing Record Series and Record Future Airing so I select Record This. When I go into the Timers listing and try to change the Record to Only New and back out a window #1276 pops open and says Timer Edit failed, Please try again later. I did a spot check of all the Prime Time channels and discovered this issue is very sporadic. Seems to be mostly CBS and ABC and not all the channels. This is happening on both my Hopper 3s. Performed a pull chord reboot but did not fix issue. I am still on U502.
CORRECTION: This timer issue is happening with Satellite and OTA locals.
Reactions: MikeD-C05
I need to correct my post. The timer issue is happening with Satellite and OTA locals.
Is anyone else seeing this local timer issue? I checked this morning and still cannot set a series timer on a few local channels in the guide. I checked a couple of the channels for every day this week in the guide and when I get into next week the series option shows up. Again, this is happening on the Satellite and OTA locals only, mostly CBS, and I am still on U502 software. Maybe I should start a new thread on this issue. Just wondering if anyone else is seeing this.
I am experiencing no local OTA timer problems. All my timers are dutifully recording programs at the proper time which are then unwatchable because of the continuing tearing and blocking video and audio dropouts.
Thanks Jon J. My timer problem is a local channel issue, both Satellite and OTA.
I have seen one timer for OTA that was giving me a fit . The timer for General Hospital could not be edited to show anything but ONCE. So I deleted the original timer and I created another and left that one for Monday as ONCE and then went forward in the guide to Tuesday and created a new timer for MON - FRIDAY and it shows it working now for the next 6 days. I tried to create a timer on the satellite version of ABC and it did the same thing . Only could created a ONCE timer and could not edit it. I tried to go forward to the next day and it still will only let you create a ONCE timer . Note that I am using Ota version from Beaumont and the Satellite version is from Houston. Something is definitely wrong in this software.
I have seen one timer for OTA that was giving me a fit . The timer for General Hospital could not be edited to show anything but ONCE. So I deleted the original timer and I left the one for Monday as ONCE and then went forward in the guide to Tuesday and created a new timer for MON - FRIDAY and it shows it working now for the next 6 days. I tried to create a timer on the satellite version of ABC and it did the same thing . Only could created a Once timer and could not edit it.
Wired issues. The four daytime CBS timers that I record all the time started acting up for this whole week. I might try out the Mon-Fri timer you have done. For today I have just set a once timer for all four programs. I guess something has corrupted my locals guide for this week for some reason. Starting next week on Monday there is no issue setting up a series timer for the four daytime CBS channels that I always record.
Well, this morning my guide is working good. I was able to set series timers for my four local CBS channels. Sure glad it is fixed now. I am still on U502.
Reactions: JSheridan
I noticed yesterday that certain daytime shows on CBS are only RECORD THIS or ONCE timers. The soap operas are like this and Dr. Phil and the Talk, but the other shows are still record series if you want to. I don't know why they are like this. I did try to edit them to Mon -Friday once they were created and I was able to change them from record once to Mon -Friday timers. It then shows it will record for the next 5 days. I could not get it to work if you changed it to NEW only. It would only record it once if I tried that. I also noticed if I changed it to NEW and then back to finish the edit , it would say Failed timer . So something is wrong with the software.
WOW MikeD-C05, those are the exact channels I had the same issue with. So I guess it was not just me. Are you on U503 or 502? I am still on U502. Anyway, they are working this morning. I was able to set them back up with series timers.
Filmon TV?
swm AND DISH METER
