Two UHF Remotes - 622 | SatelliteGuys.US
Cowchip
216
3
Minnesota
I have two UHF 6.3 remotes and would like to control the 622 with both of them and forget about the IR remote. If I could set both remotes to the same "channel" then the problem would be solved.
Thanks for your help.
Dug out the ol' manual and figured out how to set the address of the second UHF remote and all is good. The IR remote is now retired!
DISH CSR's not informed
Help needed with vip722
