:rant:How do i set up two tv set on my c band system so that when i switch a channel the other persons channel does not switch as well.
Basically, you need a receiver for each TV, and a seperate feed from the lnbf for each receiver, for independent viewing on two TV's . There are lots of slightly different combinations on that theme, but that one receiver can't support two channels at once.
This does not answer my question of splitting the signal from the lnb to both receivers. Do i need a switch or some other deviceOne other thing to consider is which provider are you purchasing programming from? If you stay on W5 all of the time it would be easier to do what you want to do.
Limited time offer
