Two sat signal in one dish | SatelliteGuys.US
sksatellite
616
Anyone suceed a two degree space sat signal in a single dish, example, G3C and G25. I can get this using a single LNBF from 36" Oval dish, but required lots twist and time consume, still chance are maybe one out of ten will succeeded. Lots time I give up before continuing.
Using two LNBF maybe the better way, but anyone try it on this ?
larger the dish, the tighter the isolation between satellites.
my T90 can probably do two deg spacing, Ive got satellites on there with 4 deg spacing and lots of room inbetween, the 1 deg marks are about 1" long on the T90 mounting bar, its quite nice.
The T90 is really hard to get 2 degree spacing due to the holder. I can get it on the ends of my arc but not in the middle
Wiring Advice?
Coolsat 6000 Invacom QPH-031 Configuration
