TVcatchup on Ipad | SatelliteGuys.US
TVcatchup on Ipad
Kraven
Resident Bozo
11,917
2,941
Northern, VT
Anyone tried adding TVcatchup on an US based Ipad? Going to attempt it tomorrow at work and wondering if anyone else tried it.
Cheers, K
I need to add it first...which is my problem. Playing ain't the problem.
Thanks tho...
Just open a UK iTunes account (no credit card needed for free apps), sign out of US account and login to UK account and it will take you to the UK store and just install as normal.
Hello,
I had a question I'm trying to sign up for a UK account not sure if I'm doing something wrong. On my laptop I have iTunes install and you said to change the country I did that. And it ask to sign up for a account but then it ask for a billing address I thought you said you don't need one for the free apps?? Or did you do it through your iPad and it does it differently?? I just have the iPhone.
Thank you,
Chris
I ended up just bookmarking the URL. Each time I tried to sign up for a UK account, it insisted on a CC. The address wasnt the problem.
Cheers, K
Samsung UN55EH6050 your opinion
Sunday Ticket on PS3
