tv2 vcr wont record | SatelliteGuys.US
tv2 vcr wont record
tski
41
hi has anyone ever run across this problem? i have a 322 receiver and the vcr on tv 2 wont record programming. the tv is set to channel 60. even if i set the vcr to 60 it will not record programming. it plays just fine. just curious if anyone else has seen this problem?
Tate Satellites said:
Your vcr is probably set to channel 60 cable not channel 60 air.
Nailed it right here. You have to make sure your VCR tuner matches the modulated channel exactly. On the vcr menu there should be a channel or tuner setting, it needs to be on "air" or uhf, then set to channel 60. After that you should be able to turn on the vcr, put the tv on 3 (or 4 or whatever you put it on to watch the vcr), and see the dish playing on screen.
Generic DP34 switches
SD 105/121 question
