TV2 hookup | SatelliteGuys.US
TV2 hookup
jb1945
SatelliteGuys Guru
138
Sacramento, California
I have a 622 that was running a Sony HD and a RCA CRT in another room. I have replaced the Sony with a Mitsubishi HD and moved the sony to replace the RCA. I transferred the coax from the RCA input to Sony antenna input and then the cable input. I have cylced through the Sony inputs and do not get a signal. The Mitsubishi is working fine. Should this be working or am I missing something? I am aware that TV2 is not HD. I will address that issue later. Thanks for any suggestions.
You'll have to select which Sony input - RF or CATV - to match which whichever output type you selected in the 622. Then is the channel setting in the Sony the same as whatever you set up in the 622? Just a couple of ideas.
hbo on broadband
Executive office
