TV2 channel selection with 222k | SatelliteGuys.US
bentjm
2,899
1,651
I just replaced a 322 with a 222k. TV2 is connected using coax via the modulator. Of course, TV2 is a SD TV. You can see the both the SD and HD channels. They look different on the screen, so I want the SD channels. I set up a favorites with only the SD channels. Using this guide everything works fine. Scrolling up and down through the channels works fine. But, if you enter the channel number directly on the remote and that channel is both HD and SD, it will always pull up the HD channel. You have to press channel down to get to the SD channel.
I looked through all of the options and did not see this as something that can be configured.
So, is this just how it is or can it be changed?
That worked, but it also killed HD on TV1. So, that is not the answer.
Thanks for the reply though.
New HD locals?
722 freezes in playback
