TV1 RF and UHF simultaneously? | SatelliteGuys.US
KAB
22,334
6,338
Fishers, IN
Been giving some though to dumping a 722 and feeding two HDTVs from my 722K (one component, the other HDMI). But, also want to keep an SD set on TV2. I have a Harmony remote I like to use in one room, but would need UHF in the other. Not sure how to do it, if at all possible.
On my 622, TV1 supports UHF and IR remotes at the same time. Mine is UHF, Mrs Pepper's is IR.
Most likely the 722k behaves similarly.
I set my 722 for TV1 UHF and it works fine. But since, the IR TV1 remote has no affect.
Yes TV1 can use both IR & UHF remotes at the same time but both (all) remotes for TV1 must be set to the same address. It just has to be diffent than the TV2 address.
722K question
VIP 722 and error message 0521
