tv tuner | SatelliteGuys.US
tv tuner
blpwrs3
va
I have a SD directv box but want to use my computer as the tv. I was told with a tv tuner I would be able to do this. Directv told me to have the channel on my computer to 3 and use the directv remote to change channels. My question is if I have a tv tuner that is also a video capture will I be able to record or do I still have to have a dvr from Directv. I have windows 7 and windows media center.
If you want to record or view DirecTV channels using the PC's tuner/capture card then you need a DirecTV receiver. I assume the PC tuner/capture card has composite inputs (R/W/Y) then use those outputs on the receiver. These will give you a better recording than the RF input. You can use the tuner/capture card's tuner for recording from an antenna.
Directv cancels BSS 17 Ghz RB 4 at 111W
HR 20-100 died
