TV Tuner/ Panel Remote | SatelliteGuys.US
  • Thread starter Thread starter Reignfire
  • Start date Start date
  • Replies Replies 0
  • Views Views 895
Reignfire
23
NC, United States
Is there a nice tv tuner without an IR extention cable for the media center remote? If not then are the drive bay panels with built in IR receivers a good alternative? If I like the remote that comes with the tuner better than the panel are you able to use any MCE remote for any IR receiver? Also if I wanted to drill a hole in my case is there an IR receiver that can be easily mounted in that hole and connect to my motherboard? Thanks for any information you can provide.
error when running windows updates
i7 bundle deal
