TV remote control conflict | SatelliteGuys.US
RayvinR
Hi my Westinghouse TV remote and coolsat remote are both conflicting each other. When I hit a button on the satellite tv it will also function for the tv simultaneously and its really annoying. Does anyone have any suggestion guys?:( :confused: :confused: :confused: :confused:
Nope... maybe get another remote? My universal remote that I use with the tv has same problems with fta receiver, vcr and audigy soundblaser on occassion. Best advice is to just get seperate remotes that don't hit the other equipment's frequencies as often... or maybe put receiver in a different part of room or further up or down on whatever it's sitting on so that you have to aim in a different direction?
Can you have 5 LNBs and motor setup to a Diseqc switch?
Wrong data on Satcalulator site?
