Tv Azteca on IA6? | SatelliteGuys.US
Tv Azteca on IA6?
Rufus_74
SatelliteGuys Guru
120
Is anyone still receiving Tv Azteca on 12076V/8741, I had been getting it until this afternoon. Could somebody please verify that the channel is still there, before I pull out all my hair!
regards
Rufus :confused:
The signal is still there, but both Azteca channels appear now to be scrambled.
It was good while it lasted!
oh its still there :)
if you have a blind scan, delete the channels and rescan. The same stuff works but the PIDs changed
you have to delete it and then just do a transponder scan of that
All of my receivers keep the info, so as an example if the channel was on 12080 H 4000 and the pids were 33 V 34 A 33 PCR and now the PIDS are 1000 V 1001 A 1000 PCR, unless I delete the original ones, every time I scan it logs the originals
Is anyone getting audio on Tv 4 from Tv azteca? I can get audio on the first three feeds, but the fourth feed is silent. Do I need to change the PIDS? Any help would be greatly appreciated.
Rufus
TV4 is silent for me...not AC3 but just silent
Have we figured oout what channel is what?
I know the first one is TV7 and the 3rd is Azteca America...but don't know about the other two
From what I have gathered, the second feed is Azteca 13, the one that used to be on Dishnet, before being replaced. The fourth one is Azteca America West(Pacific).
regards
Rufus
Intelsat 7
Will my Big Dish recieve FTA MPEG Signal?
