TV 2 Remote Address | SatelliteGuys.US
TV 2 Remote Address
textmex
65
Does anyone know how how to determine the remote address for TV2 on the 922? And can the TV2 be controlled by IR or just UHF?
Thanks!
TV2 is only available when using sling.
Now with that said all that needs to be done with the remotes you want to use on TV2 is flip the tab on the remote from 1 to 2. There isn't an address to the 922 remotes to set.
TV2 is UHF or sling only no IR
Sent from my DROIDX using Tapatalk
Thank you. It's amazing how much more knowledgeable people on this board are than the DISH tech support reps, one of whom just told me that there wasn't even a TV2 tuner in the 922. Clueless.
Anyways, I had already gotten the 32.0 remote to control TV2 by switching the tab at the bottom. I was hoping that meant that I could also get my Harmony One to control TV2.
Can I use the IR to UHF converter on the 922 that I used to use on the 622?
Thanks n0qcu. Seems like you know your stuff.
Is there anyway I can use my IR to UHF converter to control my 622 in a different part of the house if it's hooked into the same home distribution that 922 is hooked up to?
DPP44 Grounding
Scam on NBA League Pass invoicing
