tuner 2 low signal on 722k | SatelliteGuys.US
the mack
1,479
483
HOCKEYTOWN
all of a sudden I have a 20 point plus lower signal on tuner 2 then I do on tuner 1...I hooked the antenna line direct without the separator and the results were the same.
could the f connector on the tuner 2 input cause this problem? the reason I ask is I move this receiver back and fourth from my cottage at least 10 times a year and was wondering if the f connector is getting worn out?
or is this just a sign that the tuner is failing?
ok, now that I have the receiver is back home everything is fine. here at home i have a 1000.2 lnb and at the cottage where the trouble is I have a dpp44 with three dp single lnb's
seems the trouble is with the 44 switch?
Problems of this type are usually caused by bad cabling and/or bad connectors. I would suspect the receiver-side cabling (rather than the lines going to the dish.)
using all three tuners at once
DRA fails to record
