TSreader & Windows Vista | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,744
29,538
Newington, CT
My PC recently crashed so I decided to load Windows Vista on it.
Everything is working FINE except I can not get my FTA Card and TSreader to work on it.
I have a Twinhan 102g card.
I need Tsreader to work as this is how we generate our Uplink Reports.
Does anyone have a FTA card running under Vista? If yes what model? Also if yes are you using it with Tsreader?
Thanks!
Need to go to their site for your card see if they have drivers for Vista.Do that or go back to XP or get a card that is supported under Vista.
Windows Vista was just released to manufacturers last week. I am asuming you are using RC2. Several companies do not currently have complete drivers ready for Vista as they were waiting for RTM. Another thing to consider, is the card DHCP compliant? If not it will not function under Windows Vista. I would do like everyone else has said and check with the manufacurer.
one thing to try is to find the executables, dll, what not and run them in windows XP compatibility mode... that will work in alot of cases
multisport question
OTA feed TV2
