Trying LNBF tolerance for its supply voltage drop | SatelliteGuys.US
polgyver
Creative Tinkerer
490
374
Toronto
IMG_1308.JPG I tried it only for vertical polarization, where voltage fed to LNBF is about 13 V.
With horizontal, the reception would end probably around 15 Volt.
Overall, LNBF is very tolerant for its supply deficiency...
IMG_1310.JPG IMG_1311.JPG IMG_1312.JPG IMG_1313.JPG IMG_1315.JPG IMG_1316.JPG IMG_1317.JPG
Reactions: lost_mesa
The LNBF works with vertical at a much lower voltage than I would have thought. What brand/model of LNBF was used here?
I am now curious to know at what voltage it actually switches from H to v.
I always look forward to your experiments. I wish I had the time.
I notice that you are performing your testing with one of the inexpensive Far East receivers and the screen gives the audio with Dolby D displayed. Did you ever get the sound to work?
The LNBF is a cheapo Seesat. When time allows, other brands will be tried for amperage.
All receivers powered with separate 12 V power supply can play Dolby. Other receivers powered directly with cord from 120 AC, do not play Dolby.
What upsets me the most with them, is their update of transponders without being prompted to do so.
Is there FTA radio for car like XM?
1.2 meter offset or 10 foot prime focus for Ku
