Tripods | SatelliteGuys.US
Tripods
You would want a heavy duty tripod and have it anchored securely. Mast length would depend on a lot of factors, have specs and access to an engineer would get you a proper answer. If you are in an apartment, common space could put a restraint of the length.
4tanz said:
How good are tripods for patio deck installation and how long can the mast be?
If your asking about the patio mounts dish provides, they are very sturdy with the proper ballast. They normally use about 9 solid bricks for stability and that is more than enough. The mast is about 5 feet tall. Might be able to cut it down a bit, but if I remember right there are braces on the mast so I think that would affect how short it could be.
Pressing Green Button on Remote during live tv/dvr recordings
Hopper Ota question
