Triple Sat 5lnb Diseqc Question | SatelliteGuys.US
kuzn
4
Illinois
Ok here is a good question. Can you use a triple sat lnb with integraded multiswitch into a 4x1 diseqc? Also another question can you use a triple sat lnb with integraded multiswitch into a 22k switch. Also can you do the same with a 5 lnb dish?
Thanks for all the info that can be given!
5 LNB uses 250-2250 mhz will your switch support that wide a frequency range?
Well let me phrase this question a little differently. Can a triplesat or 5lnb at9 dish be put into a diseqc? I am not farmiliar with the diseqc switch and am not sure if you have to use a dual lnb for all ports on the switch in order to make it work, or can you use a multisatellite antenna into this diseqc switch and will it be able to cycle through the 101, 110, 119 and so on using one port on the switch or do you have to put the 101, 110 and 119 all on seperate ports on the diseqc switch. Also I had a question about using a triplesat with a 1 room reciever install. Can I use a 22k switch for say the 101, 110, 119 on one port, and 72.5 on the other port and will a directv reciever be able to switch between the for satellites?
Need Creative Solution for Installation Problem
What have I done !!!!!!!!!
