Triple LNB trouble.....help!!!!!! | SatelliteGuys.US
bmatt8
17
My dish recently went out of wack. And when i tried to re-position the dish,,i can get 82 signal strenght from sattelite C, but nothing from A or B. i tried 2 hours trying to pull in the signal from sat A and B but nothing. I tested the LNB on the reciever and the test showd sat A, and B failed, but C passed. Is it becasue my LNB is bad, and i have to get a new one. Please help. thanks,
PS reciever is HUGHES HD
Is the mount still plum?? If so, I would guess that the LNB went bad, or the recieber itslef. You do need to try to find signal on the 101 first, if ewverything is set properly (azimuth and tilt) the 119 and 110 will be there also. If no luck call someone.
Verify that the mast is prefectly plumb. Then set the tilt of the dish. This is critical because of the geometry of the dish to be able to point at three satellites. Since you get Sat C only, the tilt is wrong causing the other two LNBs to point incorrectly, one high and one low.
Same problem!
I have this exact problem. I have a reading of 99 to 100 on Sat C, nothing on A or B. I'm about to pull the mast down and start over after readying this. Receiver is an older Phillips, piece of junk. Want to go out and buy a DTivo unit, but want to be sure I can get sat signal here first (just moved), but keeping DTV in other house as well so they wouldn't do a moving install deal.
I've never had a problem before. This is the first time... I've done single and dual lnb setups, but this is my first triple lnb. This receiver hadn't been used in a while, could someone check the az, el, and tilt for me on one that's up to date? Zip is 23061. This rec shows 238, 34 and 55 respectively.
The dish came with a little bubble level in the top of the mast, plastic, looks like it costs $0.15 to make. I used a torpedo level on the mast itself instead like I always have before. Tried for about an hour last night. Put the plastic level in the mast this morning, and tried again. They didn't match. Had to adjust the mast. It's smack dab in the middle of the circle. Still the same problem. Transponders being used are 1, 22 and 8 according to the screen. It resets them to these anytime it goes out of the pointing screen - which is every few minutes - I hate this receiver, but hate Cox cable more...
BTW, dish is a phase iii compatible with integrated multiswitch bought locally used. Seller was using it and it had worked fine.
Any idea, suggestions, would be appreciated.
Selecting a Dish
multiple multiswitches??
