Triple LNB Connections | SatelliteGuys.US
jacksola
I'm new to the Direct TV bit. I just purchased a Travel Trailer and I purchased a Direct TV Triple LNB dish to use in the Trailer. The question is I will just use my bedroom receiver in the trailer. DO I just connect one cable to the LNB and the other end to the receiver?
Yep you got it.
Unless your using a DVR, in which case you'll want to run 2 cables.
I use a tripod set up for easy set up of the dish. (available at RV centers or online as well.)
Jimbo
Word of advice...
Make a connection point at the end of the cables coming from the LNB assembly (using 2' cables) using a ground block or barrel connector, then using your long run of cable connect to your RV.
This will make breakdown of your system a lot easier, and you won't have to disassemble the LNB arm every time.
Word of advice...
Good point,
Thats how I do it and it works great, easier for set up and break down !
Jimbo
Mediashare and Divx
HR21-100 Released - No Review Here
