Has anyone had success with using the software to update this receiver as found here: DBS-3500 software . Every time I try to use it is says "serial port probe error". I have tried it on 4 different computers and it does the same thing. Thanks.
dasfast said:Has anyone had success with using the software to update this receiver as found here: DBS-3500 software . Every time I try to use it is says "serial port probe error". I have tried it on 4 different computers and it does the same thing. Thanks.
irrelevant...it doesnt matter. The system downloads it at the same speedcharper1 said:What BAUD rate are you attemping to use? You might be set too fast.
these are two different things...straight through is pins the same...null modem 2 & 3 are swappedYou should also be using a "straight through" serial cable. (aka null modem cable)
Iceberg said:irrelevant...it doesnt matter. The system downloads it at the same speed
Limited time offer
